Just got my bolt kit! have some questions!
DrorA6
Postby DrorA6 » Sat Feb 25, 2017 6:40 am
Hey guys! :)
Just got my BOLT Kit, black limba body and walnut neck with zebrawood fretboard!
This thing looks amazing!!! :))
it's the first time im building a kit, i have tried to do a project with a cheap guitar and it came out just ok, but i have learned from this experience what NOT to do! haha
i know the first thing is to sand everything with a 400 grit sandpaper to smooth it all out.
after that i want to do a clear gloss finish (with rust oleum X2 series spray can) and tung oil the whole neck.
1. do i need to get some sealer before spraying the clear coats? or does the spray will do the trick?
2. what do i do with the neck pocket and the part of the neck that is attached to it? leave it like this? or just put tung oil?
3. the zebrawood fretboard need some treatment? (tung oil) or it can be left as is?
For some reason i can't seem to upload any pictures so i'll figure something out and post later!
Re: Just got my bolt kit! have some questions!
Postby skully13a » Sat Feb 25, 2017 9:13 am
Howdy! You're gonna have a blast, and end up with a fine guitar.
I would seal it. Reranch sells a fine oil based sanding sealer. That's what I used on mine.
I masked off the neck pocket while I was working on it, but tung oiled the entire neck(except the headstock, which I painted).
The fretboard can be left as is, unless you want to tung oil it. It won't hurt either way.
Good luck & have fun! :soapbox: 8) :mrgreen:
DrorA6
Postby DrorA6 » Sat Feb 25, 2017 11:54 am
Thanks for the response!
Since i live in israel we don't have a wide veriaty of oils for guitar woods works..
so i saw that there is a store that has rust olium "sealer" spray can will it be fine? or sould i use some kind of oil?
Postby skully13a » Sat Feb 25, 2017 2:31 pm
I dunno about Rustoleum. Maybe one of these other guys can tell you. I got mine from reranch.com
There is also a lot of good info on the website.
Postby spudmunkey » Sat Feb 25, 2017 2:37 pm
I tried googling "rustoleum sealer spray" and all I got was flexible rubber waterproofing/anti-leak spray. I definitely wouldn't use that!
DrorA6
Postby DrorA6 » Thu Mar 02, 2017 1:40 pm
Thanks for the answers guys!
i decided to coat the entire body + neck with tung oil for the sake of simplicity.
just wondered, if i would like to make a gloss lacquer finish in the future, will it be possible to sand
the tung oil and apply the gloss?
can't wait to get it started already! i will take some pictures of the process and post here when i'm done! :mrgreen:
Postby ilyti » Thu Mar 02, 2017 2:22 pm
All tung is the way to go! You are going to love the feel of that walnut bolt neck, I have one myself. I'd love to see some pics of this, sounds like some amazing woods.
DrorA6
Postby DrorA6 » Fri Mar 03, 2017 12:36 am
Thanks ilyti!
I will start sending the guitar today hoping to get it all done by next week! :stir:
There are some pictures! i will get better ones and open a thread about the build process!
Enjoy! :D
Postby wickid » Fri Mar 03, 2017 8:24 am
DrorA6 wrote:Thanks ilyti!
Enjoy! :D
Nice, I was wondering how the limba would look with a black PG. Thanks.
Black hardware too?
DrorA6
Postby DrorA6 » Fri Mar 03, 2017 9:30 am
Enjoy! :D
Black hardware too?
yeap, black hardware, locking tuners and a wilkinson tremolo...
can't wait to get it all ready for jamming!!
Postby skully13a » Fri Mar 03, 2017 10:02 am
DrorA6 wrote:Thanks for the answers guys!
Yes, you can resand and refinishing, while not super easy, is not that hard to do. Tung oil doesn't penetrate deeply so it's quickly sanded off. It just doesn't seem quick then. Like always.
Some sweet lines on that body, and the board. That will be a good looking guitar. 8) Makes me want to get another one.
Postby spudmunkey » Fri Mar 03, 2017 10:11 am
If you use an oil-based poly (instead of water-based), you wouldn't even need to sand it first...although working with it isn't quite as easy as dry times are much much longer. With water-based you MIGHT be able to get away with it, but it's better to avoid it.
Some people will use an oil like a Danish oil for color, then put a poly over it...but danish oil is a but different than plain tung oil finish...
DrorA6
Postby DrorA6 » Sat Mar 04, 2017 12:16 am
spudmunkey wrote:If you use an oil-based poly (instead of water-based), you wouldn't even need to sand it first...although working with it isn't quite as easy as dry times are much much longer. With water-based you MIGHT be able to get away with it, but it's better to avoid it.
this is what i am going to use, i don't know if this is a water based or a poly one..
DrorA6
Postby DrorA6 » Sat Mar 04, 2017 5:04 am
Just finished sanding the body and neck!!
i'll open a new thread for the whole process, but in the mean time here's a little teaser!!
Praiser
Postby Praiser » Sat Mar 04, 2017 10:34 am
Can't wait to see this one come together!
That body wood is really, really nicely grained!
Please hurry up. :mrgreen:
John
XP1000L, LM153s, LS1801A
Peavey Fury P Bass
Postby Coda » Sun Mar 05, 2017 6:18 pm
Wow, that body looks amazing! :applause:
Postby spudmunkey » Sun Mar 05, 2017 7:09 pm
To clarify, I was talking about the clearcoat over the oil.
DrorA6
Postby DrorA6 » Mon Mar 06, 2017 9:59 am
Ohh i see! thanks! if i'll ever think about getting the guitar with gloss finish i'll manage somthing :)
