Carvin Guitars, Amplifiers & Pro Audio   Please abide by the following rules:
  a. For issues with shipping, repairs or complaints, use the CONTACT page.
  b. No private sales, auctions or advertising services allowed.
  c. No topics of a political or religious nature, profanity, flaming other members or general bad behavior.
  Guitars        Basses        Guitars In Stock        Parts & Accessories        Merch        Artists
 Carvin Museum   FAQ   Search the BBS   Members   Register   Profile   Log in to check your PMs   Log in
V3M Schematics?
Goto page 1, 2  Next
Post new topic   Reply to topic    KieselGuitarsBBS.com Forum Index » Customer Service & Technical Support View previous topic :: View next topic
Jump to Bottom of Page
V3M Schematics?
 PostPosted: Tue Jan 10, 2012 10:22 pm Reply with quote
Message
  Spoons
Offline
I can't find the V3M schematics on www.carvinservice.com/crg/schematic_finder.php
Does anyone know if they have it available yet?
View user's profile Send private message
re: V3M Schematics?
 PostPosted: Tue Jan 10, 2012 10:24 pm Reply with quote
Message
  Mr. Scott
Offline
usually you would have to ask but a lot of it is going to be blocked out anyway due to it being new. The whole preamp design is blocked out
re: V3M Schematics?
 PostPosted: Fri Jan 13, 2012 1:38 pm Reply with quote
Message
  Volt
Offline
I understand why no schematic yet. I'd like to see a block-diagram of one, however.
re: V3M Schematics?
 PostPosted: Thu Feb 23, 2012 6:50 pm Reply with quote
Message
  Volt
Offline
Anxiously waiting the schematic to be released.............so i can "fix" the tone of the overdrive channels.........so I will be able to use The V3M as a multi-channel amp........and will no longer need to use my stompboxes for overdrive.
re: V3M Schematics?
 PostPosted: Tue Mar 27, 2012 5:53 pm Reply with quote
Message
  Volt
Offline
I'm in the process of making a schematic of the tone control circuits. Very time-consuming, tedious, and a task prone to mistakes.
The front end circuitry is very similar the the V3 schematic I have, but after that, not very much is agreeing with the V3.
I just started today, but already I see that channel 3 has an unusually small cap for the mid control.
IMO this is a good amp that has the potential to be a great amp!
_________________
V3M amp
re: V3M Schematics?
 PostPosted: Tue Mar 27, 2012 6:15 pm Reply with quote
Message
  Spoons
Offline
The only thing I'm wanting to change in the V3M is the amount of drive on the overdrive channels. Right now I'm running mine at 50 watts, with one drive set just above 1, and the other drive is set just above 3.
Personally, I'd like to cut the drive in channel 2 by something close to 3/4 and the channel 1 cut by about half that way I have two "independent" channels with two different drive structures. I don't think I'll eve use the drive set above 5 the way it is set now.
_________________
V59K, SC90-HH, SC90-SSS, TLB60-SSS, SH275, Axe-Fx II w/MFC-101, Roland GR-55, Line 6 G90, EM900 In-Ear, V3MC, Jettenuator, Legacy 2X12, TS100, DCM150, C844, EQ2030, AC120S
re: V3M Schematics?
 PostPosted: Wed Mar 28, 2012 7:29 pm Reply with quote
Message
  Volt
Offline
So, if I understand you correctly, you use very little overdrive on channels 1 & 2 and would like even less overdrive?
I usually have my channel 2 drive at about 3 or 4 and channel 1 drive at about 6. On the rare occasion that I want mass quantities of OD I add my Boss OD pedal to channel 1's OD. Shocked
The bass, mid, and treble tone controls are fairly straight forward, but the drive controls are rather confusing at the moment. I may have made some errors ciphering them.
NOTE: I can't reveal any schematic details since Carvin hasn't released the schematic yet.
EDIT: After correcting a few errors I made I found that the tone controls are a fairly unusual design.
_________________
V3M amp
re: V3M Schematics?
 PostPosted: Wed Mar 28, 2012 9:32 pm Reply with quote
Message
  Mr. Scott
Offline
replace V2 with a 12au7, you will be amazed at the difference. You can even go as far as a 12at7, I would try this first before you start swapping parts on a board.
Re: re: V3M Schematics?
 PostPosted: Wed Mar 28, 2012 9:35 pm Reply with quote
Message
  Spoons
Offline
Who was that message for?
_________________
 PostPosted: Thu Mar 29, 2012 3:08 pm Reply with quote
Message
  Mr. Scott
Offline
you, it will lower the gain structure and tighten up the low end some and make it more musical
 PostPosted: Thu Mar 29, 2012 3:32 pm Reply with quote
Message
  Spoons
Offline
Based on your experience, how much will it reduce the gain structure?
Are the top two tubes on the followinglink what you are talking about?
http://www.jj-electronic.com/index.php?option=com_content&task=view&id=15&Itemid=13
_________________
re: V3M Schematics?
 PostPosted: Thu Mar 29, 2012 9:38 pm Reply with quote
Message
  Krasneypoley
Offline
Choosing pre-amp tubes by gain factor-
http://thetubestore.com/gainfactor.html
re: V3M Schematics?
 PostPosted: Tue Apr 03, 2012 8:09 pm Reply with quote
Message
  Spoons
Offline
Ordered (2) JJ 12AT7's today, gonna give this a try.
I'll post a report after I get it done.
_________________
re: V3M Schematics?
 PostPosted: Wed Apr 04, 2012 11:10 am Reply with quote
Message
  Volt
Offline
The 12AU7 noticeably reduces channels 1 & 2 gain, and also reduces their fuzziness - good for vintage blues/rock. I increased the drive levels to how much OD I had before the tube swap and the fuzziness returned.
12AT7: The reduction in gain was hardly perceivable.
Of the two tubes I prefer the 12AU7. Your mileage may vary. Smile
_________________
V3M amp
re: V3M Schematics?
 PostPosted: Mon Apr 09, 2012 8:33 am Reply with quote
Message
  Spoons
Offline
I haven't even got the new tube to try reducing the gain yet and the V3MC started fading in and out on the gain channel at our warm up rehearsal yesterday morning. The clean channel sounded like it was working properly. This amp only gets used for about 45 minutes to an hour every other week so it's only got about 9-10 hours on it. I certainly hope this is a simple V1 or V2 tube swap issue.
I sent a message out to customer service this morning.
Sad
P.S. It is exactly because of these kind of routine issues with tube amps that I use an Axe-Fx Ultra for my main rig.
_________________
re: V3M Schematics?
 PostPosted: Mon Apr 09, 2012 9:00 pm Reply with quote
Message
  Spoons
Offline
Since I had absolutely no replacement tubes to try in the amp, Carvin customer service is sending out (2) 12AX7's to replace V1 & V2, hopefully that'll fix it, I'm guessing it will. I bet the tubes from Carvin get here LONG before the 12AT7's JJ's that are currently back ordered from GC. Since I only use the V3MC as a backup amp and use it every other Sunday morning for our brief warmup rehearsal I'm really in no big rush. I always have a backup switchable SS Roland Cube collecting dust in the closet since the V3MC showed up. I even have multiple backups for my backups, LOL!!
_________________
re: V3M Schematics?
 PostPosted: Wed Apr 18, 2012 7:50 pm Reply with quote
Message
  Spoons
Offline
The two replacement 12AX7 tubes seems to have fixed the fading problem.
_________________
re: V3M Schematics?
 PostPosted: Wed Apr 25, 2012 9:41 pm Reply with quote
Message
  Spoons
Offline
Well after the original factory tubes in V1 and V2 were replaced to fix the fading in and out problem, I was willing to put my new tubes in when they arrived a couple days ago and give them a try.
V1 = JJ 12AT7
V2 = JJ 12AT7
V3 = No Change
V4 = No Change
I think this retubing has done just enough drive reduction to satisfy my taste. I've now switched the Mode switch to "THICK" & switched "ON" the EQX for both channels 1 & 2. Switching the V1 tube to the 12AT7 did little to effect channel 3 the clean channel, I think it might have given me a little more finesse to get a little extra "umph" before it starts to get that touch of of break up - I run the clean channel on BRIGHT. I love the baseline tones across the three channels and with a simple flip of the MODE switch I can take it into hair raising high gain territory or some very sweet sounding blues. About the only thing I'm missing on this amp is to ability to switch it via MIDI.
Overall what I was looking for was more ability of finessing the drive at lower drive levels, this tube switch has solved that for me.
_________________
re: V3M Schematics?
 PostPosted: Thu Oct 10, 2013 2:32 am Reply with quote
Message
  RetArmyEng
Offline
I actually stumbled across this thread while looking for V3 Schematics. Specifically I wanted to see what the V3 MIDI circuit looked like.
I would like to mod my V3M with a MIDI circuit so I can use one controller between my amp and Eleven Rack.
 PostPosted: Thu Oct 10, 2013 9:32 am Reply with quote
Message
  Spoons
Offline
RetArmyEng,
Thanks for your service.
I'm not too sure you'll be able to modify the V3M in such a way; I'm pretty sure it requires an additional board to be installed and the inside of the V3M is pretty darn cramped as it is right now. You'll probably have to use an external MIDI switcher to accomplish what you want.
P.S. I'd really like the V3M to be MIDI controllable too. As far as I am concerned; in today's technological world, ALL heads that have more than one channel and multiple modes should be MIDI controllable - no exceptions. The ONLY thing preventing this from happening is cost which can be passed directly on to the consumer.
_________________
Page 1 of 2
Top of Page
Goto page 1, 2  Next
Display posts from previous:
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Join Carvin Guitars on Facebook! Follow Carvin Guitars on Twitter! Subscribe to Carvin Guitars YouTube Channel! Follow Carvin Guitars on Instagram!
The views and opinions expressed on the Kiesel Guitars BBS are solely the responsibility of the authors, and do not necessarily reflect the opinion of Kiesel Guitars / Carvin Guitars. The KieselGuitarsBBS.com administrators will block all e-mail addresses violating the established BBS rules. Topics that are not based on Kiesel Guitars / Carvin Guitars gear or experiences with Kiesel Guitars gear may be subject to deletion.
