"Dark" Tung Oil
crypto
"Dark" Tung Oil
Postby crypto » Fri Aug 19, 2016 10:52 am
Just ordered the following after months of putting variations of this into my cart over and over again while I saved up money:
NWAL - Walnut Neck & Body $100.00
-IN - Inline Headstock (Standard) $0.00
EFB - Ebony Fingerboard (Less Color Variation) $40.00
NIN - No Top Inlays - Side Dots Only $0.00
-WSD - Standard Side Dots (Standard) $0.00
STF - Stainless Med-Jumbo Frets .048" H .103" W $40.00
-R14 - 14in Fretboard Radius (Standard) $0.00
-S6A - 3 S60A Alnico Single-Coil Pickups w/ 5-Way Switch $0.00
-400 - Black Pickups (Standard) $0.00
BC - Black Hardware $30.00
-1046 - 1046 Light Gauge .010 - .046 (Standard) $0.00
CL - Carvin Locking Tuners $30.00
BG - Black Multi-Layer Pickguard $5.00
SC10 - Black Ultimate Soft Guitar Case $60.00
Now, figuring out how to finish it; does anyone have any experience with "dark" tung oil? Found something here, but I'm just wondering if anyone has tried something like this before.
re: "Dark" Tung Oil
Postby ilyti » Sat Aug 20, 2016 11:20 am
Sweet bolt build! IMO walnut is plenty dark that regular tung is perfect. If you want it almost rosewood-dark you could try dark tung, but I have no experience with it.
re: "Dark" Tung Oil
Postby spudmunkey » Sat Aug 20, 2016 11:27 am
Sounds cool. Not entirely sure I like it on this wood example, but I'm sure walnut would be different.
crypto
re: "Dark" Tung Oil
Postby crypto » Sun Aug 21, 2016 9:30 am
Yeah, I think I'll wait to see how dark the wood is and then decide!
MichaelGA
re: "Dark" Tung Oil
Postby MichaelGA » Tue Aug 23, 2016 6:38 am
Make sure you wet the wood to simulate what it would look like with a clear coat before you decide. I have attached a link to a Warmoth body with a walnut top that has pictures with and without being wetted. It makes a big difference!
http://www.warmoth.com/Showcase/Showcas ... 7xRoU32bZ4
Michael
crypto
re: "Dark" Tung Oil
Postby crypto » Wed Aug 24, 2016 3:59 pm
Thanks! That's super helpful. I might start with a stain too like this kit build; http://gwfweb.com/guitars/pages/bk4a.htm
re: "Dark" Tung Oil
Postby spudmunkey » Wed Aug 24, 2016 4:38 pm
A suggestion to look into: Wipe it with alcohol rather than water. You need more water to get the same effect, and water soaks in and then you have to let the body dry again for a while. Alcohol basically evaporates without effecting anything...at least, the few times I've done it. :think:
