Need To Replace An Oddball Jack
Stargazer735
Postby Stargazer735 » Thu Mar 01, 2018 5:32 pm
I'm in the process of rewiring a 1977 CM-140 and, just when I thought I had everything I need, I've stumbled across a bit of an issue: it looks like one of the jacks is pretty hard to find.
Apparently, these used a special variation of L11 jacks that were 3 terminals instead of 2, and allowed for switching between mono and stereo whenever the 2nd jack was plugged in. It's 3 terminals, but not a conventional stereo jack.
See the diagram below for reference:
http://www.carvinmuseum.com/decade/imag ... iring.html
For the life of me, I can't find this type of jack anywhere on the web. Does anyone know where I might obtain one?
Buckeye Burl/White Limba CS6 w/ Walnut/White Limba neck, Lithium Pickups
Black Limba'd Carvin DC127 w/ Graphtech Piezo Floyd Rose, M22SD & M22N Pickups
Spruce/Walnut AC375
SX300 100W 2X12 amp in Python Snakeskin
Avid astronomer, lover of stringed instruments and Led Zeppelin fanatic
Re: Need To Replace An Oddball Jack
Postby spudmunkey » Thu Mar 01, 2018 7:37 pm
Huh... I never thought much about it, but I guess I always just assumed that the mono summed to stereo split happened because of how the jacks were wired, and completing or breaking circuits, rather than a special type of Jack. :think:
Stargazer735
Postby Stargazer735 » Fri Mar 02, 2018 7:56 am
Yeah, they're special transfer jacks.
Switchcraft makes one called an L12A, but apparently, it's not the same thing.
I sent a ticket into Kiesel, but no response yet. :(
Spruce/Walnut AC375
Postby UnexplodedCow » Fri Mar 02, 2018 12:00 pm
Do you have a picture of the physical jack in need of replacement?
That component layout picture looks like a regular mono switching jack (IE: the L12A).
Maybe the 14B jack will work? It's a stereo dual switching type.
Or the 13A? It's a dual switcher for mono. The positive connector either hits the ground, or passes to another output. Might be what you need. (link: https://www.mouser.com/ProductDetail/Sw ... 0UzOgSc%3D
Here's another link with more pictures: https://www.parts-express.com/switchcra ... --093-1003)
I typically use the 12A style for adding an external speaker jack to a combo amp, so it switches to the internal speaker normally, and then shuts it off to run external, so it could be used in an alternative wiring scheme that would otherwise have no sonic difference.
