Set up
pauldrock
Set up
Postby pauldrock » Sun Nov 10, 2019 1:01 pm
Do Kiesel guitars come set up from the factory ?
Re: Set up
Postby spudmunkey » Sun Nov 10, 2019 1:52 pm
Yes, but if you have specific strings you'd like to send in, or tuning you want to use, let your salesperson know at the time of order (not after).
pauldrock
Re: Set up
Postby pauldrock » Fri Nov 15, 2019 11:20 pm
its a great guitar but it docent play right have to have it set up by my guitar guy there some dead frets on the g string up past 15 fret I'm sure it play like better after its set up properly
SilkyHotLicks
Re: Set up
Postby SilkyHotLicks » Tue Nov 19, 2019 4:03 pm
I've been resisting my impulse to reply to this post but I had an experience on Saturday that ties in to your question.
Firstly, I have never purchased a guitar with my preferred strings and my preferred setup and I personally own over twenty. Which means that every one required another setup with intonation adjustment and sometimes a truss rod adjustment. I'm glad that I took the time to learn how to do it myself
Secondly, I was at a local boutique builders shop on Saturday when a guy walks in, picks up the most expensive guitar in the shop and then begins to complain that the guitar is setup is wrong. I pick it up and it feels and sounds great to me.
The difference is 1mm. This particular builder sets his guitars at a 2mm string height at the 17 fret which is perfect for my style of playing but apparently not for this guy as he prefers 1mm or lower. LOWER, Wow :|
